Amp Question... Help plz!
Seem to have found the problem. I guess I'm not getting adequate voltage from my remote wire. When I run the remote wire directly from the amp to the positive post on my battery my amp would turn on with the power light lit up as usual. After doing some research hifonics suggest adding a relay. So i have a project for tomorrow morning.
How did you set your gain?
My gain has always been set a little past half. And it was working fine then all of a sudden while I was driving just turned off. So now I'm wondering why now all of a sudden would my remote wire voltage be bad?? Is this something that could be fixed with adding another battery, big three upgrade?
You were probably clipping. And your remote wire could either be burned or loose.
rick817
rick817
Arlington, Tx
Falcons
