amp problem!
lovick19
Ohio
Amp will not work unless the remote wire touches a strand of the 12v power wire could it be a blown fuse? I tried running new remote wires. It is not a bad amp because i hooked it up directly to another car and it works. Also when i have it hooked up the subs cut out sounds like not enough power is gettin to it
It's hooked to the rem wire in the back of the hu it's right I checked I think I have a powe problem like blown fuses or something which fuses should I check
Just run a new lead to the fuse box from the amp and use any accessory that turns on with the key.......or even acc. fuse location. At least you will know if its the turn on lead or not coming from the amp......
lovick19
lovick19
Ohio
parkerguy
