Amp problem, need help ASAP
Well the supplied wire is tapped into the power ant wire, hence why it works with the radio and shuts off when you change to CD mode. Need to trigger the amp off a different wire...
on your radio harness
you probably used the Power Antenna wire as your remote which is a SOLID BLUE wire
you need to use the REM wire which is BLUE with a WHITE stripe connect that to the blue scoshe wire that goes to the amp.
the power antenna wire is only live when the AM/FM radio is on, and turns off with CD/etc.
Anonymous User
****** FTW!
Anonymous User
Bay Area, CA
azbass
Mike Mccabe
