Amp problem!!HELP PLEASE
i have 2 12" pioneer champion series and a jl audio 500/1 amp ground, power, rca cables and remote wire are all hooked up and the amp power light is on
subs are hooked up also with speaker wire
subs will not work with rca cables hooked in the regular input side located on the right, the only way they work sorta is if i put one in the pre amp output side and the other in regular input side, ive had subs before and never had this problem it was always plug and play.
even when 1 rca is in the preamp side then one in the input side it still dont hit like it should + i can hear my exhaust threw the speakers,
mabbe i need new rca cables? everything else is hooked right
Cud this be a bad amp ground?
pictures of the back of the amp
imgur: the simple image sharer
Mikeydapro
Mikeydapro
Blackwood, NJ
Mikeydapro
