Helllllllllppppp!!!!!
yroc434
Va
set up:
CAR--------> 2005 Nissan Altima
Head Unit---> Pioneer DEH-4600bt
AMP--------> Hifonics BRX2000.1D w/bass knob
Subs-------> (2) 12'' Alpine Type R's (SWR 12D2) 3---1000watts RMS 3000 watts PEAK
so here's my question.... when setting the gain on my amp should i turn it up as far as it can go and turn the bass knob all the way down to its lowest point then gradually turn it up? ive noticed that i have to turn it 3/4 the way up with the knob to get decent bass and right now its set about halfway on the amp? also can someone look up this deck and tell me how i should have the settings set b/c there are things that i dont know about!! im just getting into car audio so i dont know much at all!!! also when you reply can you talk my language lol b/c audio terms confuse me!!! THANKS A LOT
Sounds about right to me with the gain and remote knob. Ideally you should have enough play in your volume/remote gain knob that you can get max output out of the lowest record level music you have.
As far as audio settings on your head unit there's probably a shitload of them. I'd think some playing around and taking notes would probably get you a good idea... if it sounds good it is good! And if you run into anything you can't figure out what it's doing just come back and ask specifically.
Ok here are some specs on my equipment:
Enclosure: Ported
Width: 38"
Height: 14"
Gross Airspace: 1.71 cu. ft. per chamber
Net Airspace 1.48 cu. ft. per chamber
Port: 12"x 1 1/4"x 19"
Port Volume: .23 cu. ft. per chamber
Subs: (2) 12" SWR 12D2 (wired @ 2ohms)
Frequency Response: 24-200hz
Power handling: 300-1000 watts rms/ sub
Sensitivity: 84db
Ported box: 1.25-1.50 cu. ft.
Amplifier: Hifonics BRX2000.1D
2 ohms 1400x1
LPF: 35-250hz
Subsonic Filter: 15-35hz
Frequency response: 10-250hz
Trying to set my LPF & SSF where they need to be!!!! Help please
yroc434
yroc434
Va
yroc434
