Amp problem, 1 rca louder than 2?
You mean negatives off the right channel ?
Sorry bad fingers.
but yes, you eliminate the negative output from one side and the positive output from the other and use the remaining outputs as a single mono channel.
So would I take the wires from both speaker terminal cups and match the positives and negatives. and run the positives to the right channel positives, and the negatives to the left channel negative, and then itw ould be bridged?
What ohm would the amp be seeing doing this though?
Ok you already answered before I could ask, but what about the ohm load?
I am not sure what this amp can handle, but I have heard it is very underrated and can take some abuse
What are the sub woofer voice coil ratings for each coil.
EG-what is the ohm rating for each individual coil, you have two DVC subs so you have 4individual coils.
according to that it should be 2 ohm right?
my.php
This will provide the same amount of power to the subs that they are getting now but they will be recieving a mono signal so they share the same amount of power at all times.
It will just stop working until you shut down the system and restart it, most amps have a protection circuit in them that shut them down in the event of overheating, improper ohm load or incorrect polarity on the power terminals.
jucaraman
jucaraman
Midwest, MO
stones
