Amp on the box?
muffinman944
BITTER Army Officer
OK, big time nooooob question here....
Is there anything wrong with mounting the amp on the sub enclosure???
Vibration is the only thing I can think of, otherwise cant really see why not to do it.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
(Flame me if you want, i just wanna make sure before I do and dont have any audio buds to ask here..)
My home sub has a huge weight in it to prevent movement, and the exterior of the box does not vibrate at all
my sub enclosure in my car vibrates a good bit
A weight in it to prevent movement? Say what? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
My home sub is no different than my car sub... other than it has a plate amp attached to it, and the exterior finish is different. Oh yeah, and my home sub doesn't bounce and vibrate around inside a moving automobile.
If your amp vibrates when attached to your box, you didn't brace the box well enough.
yes....speaker boxes with weight in the base to keep the box from scooting around on the floor
What does that have to do with anything? If you bolt your car sub box down, it won't move around either. Not that it matters, because it won't stop your car from moving and vibrating everything inside it as it moves down the road.
you said weights and a confused smiley....I explainedi
I would recommend to not mount the amp on the enclosure any time you can avoid it but i understand the limitations in some system designs.
If you must mount the amp to the enclosure, use rubber grommets or spacers between the amp mounting feet and the enclosure.
This will dampen out some of the vibration.
x2
Werd!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Obviously the amps gonna be subjected to vibration no matter where you stick it, but, your right, on the box its gonna be x2 (dont see how thats good for any electronic device).
Im running 2x 18'' Fi Qs w/bp (or maybe 4 x new Mags), so Ill stick to the floor, or get a THICK rubber gasket with a mounting plate on top and mount the amp to that.
Thanks alot!!!//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
muffinman944
BITTER Army Officer
muffinman944
Harlingen, TX
muffinman944
