Amp losing power
I used a 4 gauge ground. Not much difference. Should I get some 4 gauge for the woofer to the amp? Or 0 gauge? Next check I am going to buy a 160 amp alternator, run 0 gauge, big three, and run bigger wiring to the woofer, if that doesnt solve it, I will see if the amp is fucked up, if so ill buy a new amp.
have you tried swapping RCA's?..you said you didn't think it was in protect, sot it sounds like maybe a bad rca connection. Also check your battery out and see what the resting voltage is. if it is an older starting battery, it may have a bad plate and about to bite the dust. you need a good AGM deep cycle battery up front and upgrade the wires on the charging system (big 3). I would do that before buying a new alt, since the system will need it anyways, no matter what alt you buy.
GrindFrog
GrindFrog
Pryor, Oklahoma, United States
quackhead
michigan born
    May 14, 2026
michigan born
    May 14, 2026
