Amp is getting hot, cause?
Kicker ZX amps take 1/0
That's nice to bad he's using a kx, don't kicker amps run warm anywho I know with my sx amps WITH coolin fans still sitting temp of 90-110 degrees. Me thinks he has a loose fuse or the wire going to the amp is loose in the distro
The kx manual calls for 1/0. The reason i have a dist block was because at first i intended on running two amps. I didnt use the second amp, so i just pulled the second wire from the block leaving 1 4gauge wire leading to the amp. The wire itself is about 1ft long. Its ****** wire, believe me. And no my gains are about only half way up. The only wire that was warm was the 4 gauge, so im assuming thats the issue and im going to just run the 1/0 directly. And today was about 80 degrees. Ill check all my connections and see if the problem persists. Oh and the subs are wired for a 1 ohm final
I'm pretty sure Kickers aren't 1 ohm stable, that's why it's getting hot
UPDATE: yesterday i was playing it for a bit in the afternoon and it got warm, but then it started to skip (clip) on some of the songs with more bass than usual. my brother had this amp before me for a few years and he said it would skip, so im pretty sure he clipped it on quite a few occasions. i have another amp identical, so i might swap them and test the other one. at this point i think that the amp is probably damaged to some degree. i also removed to the distro block and ran 1/0 directly to the amp.
Yea im that guy, no more amp strapping though. Gain is half way and the bass bost is off. I was about to put in a new alt but some members on this site suggested i didnt need one for just one amp.
marquisbrah
marquisbrah
fresno cali
marquisbrah
