Amp for my subs????
yzjon13
I have 2 12" Rockford Fosgate P1 Punch Subs they run 150w rms 300peak they are 4 ohm and i have them in a ported box. What im not sure about is which amp to go with. If anyone can tell me an amp that'll work with my set-up it'll be helpful, Im looking to spend around 200 bucks or so.....
If they are single 4ohms and you are paralleling them to 2 ohms you can try a kicker zx300.1 or a cadence xenith 300.1 both are single channel 2 ohm stable. They do true power and are right at $200
yes if the subs are single 4 ohm voice coils then you can parallel them to get 2ohms of series to get 8 ohms but you usually dont want to run 8 ohms. The12volt.com has a ohm calculator on their site if that helps. But if you have 2 single 4 ohm woofers you want a single channel 2 ohm stable amp. Like the kicker or cadence.There are a bunch of brands that will work as well
The kicker amps are nice they come with a birth sheet so you can see what the power that you are going to get is. Kickers are also under rated so you will get more power than 300 watts
yzjon13
yzjon13
Ludlow, MA
yzjon13
