Amp cutting out? Any idea why
PESteele
I wang on an 8 in a van
i put an RL-i powered by a orion 3002. For some reason now when i was playing I want to Fuck you by akon it would cut off when playing hard and then come back on 2 or 3 seconds later. Any idea why this would be occuring. When it cuts off the amp turns off. Any help would be great.
strange indeed. Did u double check all grounds. I know one time I had a problem with my fuse holder messing up. When I would hit a bump it would cut out and then come back on. I just put a new fuse in and it works fine now
dont know. i hooked it up to the remote turn on from the amp today instead of having the turn on in a switch directly from the battery. Ill check the grounds again though to see it it helps
the light turns off. I dont know if this amp has protect . It definitly doesnt have a protect light unless the led turns a different color.
i have the same problem'but check your voltage to see if its dropping too low
how the output when playing that song by the way
i know the 8 is loving it
80
the output is pretty good for an 8. Def fits my dads needs. Amazing sq but the stock sub is still in there and i cant figure out how to get it undone which takes away from it a little when your not sitting up front
PESteele
PESteele
annapolis
PESteele
BP1Fanatic
BP1Fanatic
