Amp and Subwoofer Setup
I was given some equipment by a friend of mine and am totally confused. He gave me two amps, both Sony Xplods and I am unsure of which to use. One is a XM-4060GTX and the other is a XM-502Z. The sub is a Audiobahn AW831T.
Which amp would be a better match for this sub?
I'm also confused about how to wire the sub. It came in an enclosure with the positive and negative cables split with the two positive leads going to the two positive speaker terminals and the two negative wires to the negative terminals. Is this correct?
XM-4060GTX
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/158/158XM4060.PDF
60 watts RMS x 4 at 4 ohms
75 watts RMS x 4 at 2 ohms
60 watts RMS x 2 + 150 watts RMS x 1 in 3-channel mode
4- or 3-channel output (no 2-channel operation)
Tri-way capable (Tri-Way crossover required)
CEA-2006 compliant
requires an 8-gauge wiring kit — wiring and hardware not included with amplifier
MOSFET power and output stages
rear-channel high-pass/low-pass crossover (50-300 Hz, 12 dB/octave)
front-channel high-pass crossover (50-300 Hz, 12 dB/octave)
preamp- and speaker-level inputs
gold-plated connectors
variable bass boost (0-10 dB at 40 Hz)
XM-502Z
http://www.docs.sony.com/release/XM502Z.pdf
60Wx2
120Wx1
what impedance is the sub? single 2 ohm or 8 ohm?
Audiobahn AW831T 8" Natural Sound Series Subwoofer AW 831T
you can't drive a mono 2 ohm load and you don't want to drive a mono 8 ohm load. in order to use those amps, you want a mono 4 ohm load.
refer to the manuals for wiring instructions when using a sub.
Bob Chadwick
Bob Chadwick
Atlanta, GA
Bob Chadwick
