Amp and Subs question
DupeZ
MA
Just picked up these
SUBS
* Brand New Audiobahn ABP10T Dual 10" Bandpass Enclosure Loaded w/2 10" Subs
* 600W RMS Total Power Handling
* 1200W Max Total Power Handling
* 2 Ohm Mono / 4 Ohm Stereo Operation
* Curved 3/8" Plexiglass Window
* Mirrored Interior Panels
* Blue Neon Interior Lighting
* Gold Binding Posts
* Spun Aluminum Venturi Ports
* High Quality MDF Construction
* Sensitivity: 101dB
* 2" 4-Layer ASV Voice Coils
* Molded Textured Injected Poly cone
* Extended and Vented Pole Piece
* Frequency Response: 30Hz - 150Hz
* Dimensions: 12"H x 26"W x 17" / 10" (Bottom Depth/Top Depth)
AMP
* Brand New A8000V Audiobahn Mono Block 800W RMS Intake Series Car Amplifier
* Double Sided Glass Epoxy Circuit Board
* High Gloss Chrome Plated Finish
* Variable High/Low Pass Crossover
* Variable Subsonic Filter
* Bass Boost
* 3-Way Protection
* RCA Throughout Connections
* Digital Volt Meter with Cobalt Blue Illumination
* Air Induction Fan Cooled
* Cobalt Blue Illumination Side Stripes
* 2 Ohm Mono Stable
* MOSFET Power Supply
* 1x 800W RMS @ 2 Ohms
* 1x 400W RMS @ 4 Ohms
* Dimensions: 12" x 2-1/8" x 12-1/2"
so i went to Best Buy and they installed it with a rockford 4 gauge kit. im not sure if they wired it 4 ohm or 2 ohm. pretty sure they did it 4 ohm since my friends sounds similar. any way i could tell what they wired it? would 2 ohm be too much for those subs, and would it be hard to change it to 2 ohm? thanks.
pull out a dmm and check, or you can take out the subs to see how they wired it. there's no audible difference whether it's wired to this ohm or that ohm. btw, how much did they charge you to just install the wires?
70 for the installaton
5 for materials
12 for battery terminal
100 for 4 gauge rockford wires ( the walmart kit i bought wasnt long enough)
wouldnt 2 ohm have more bass comapred to 4 ohm? it sounds great how it is now.
also, my front input for my ipod isnt working anymore. its not apple brand but its a headphone end at each end of the cable that plugs into the front of the cd player.
DupeZ
DupeZ
MA
Kaltenberg
