Amp and sub question
  • 2
rb042hou
I have a zapco mono amp.
150 watts @ 4 ohms
250 watts @ 2 ohms
500 watts@ 1 ohm stable
The sub is Image Dynamics
Dual voice coil rated 250 watts @ 2 ohms.
Can I wire it in parallel to 1 ohm?
What will the amp be sending to the sub?
Will it blow the sub?
Does it send 250 watts to each voice coil?
My understanding is that if I wire it in series than it becomes a 4 ohm load to the amp. But don't only want to send 150 watts to sub. Any help is appreciated. Thanks
if its a dual 2 ohm coil, yes
optimally, 500
depends on the box. if its ported, maybe. if its sealed VERY unlikely
optimally, yes
see answers in red above. as long as your amp puts out 500 rms at 1 ohm, then youre questions are valid and you should be good. Just be careful when pushing it too hard/low in a ported box and avoid clipping at all costs unless you want to blow the woofer
383
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
570
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
563
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
rb042hou
rb042hou
rb042hou
Brendon Jenness
    May 8, 2024
    May 8, 2024
