Amp and sub question
rb042hou
I have a zapco mono amp.
150 watts @ 4 ohms
250 watts @ 2 ohms
500 watts@ 1 ohm stable
The sub is Image Dynamics
Dual voice coil rated 250 watts @ 2 ohms.
Can I wire it in parallel to 1 ohm?
What will the amp be sending to the sub?
Will it blow the sub?
Does it send 250 watts to each voice coil?
My understanding is that if I wire it in series than it becomes a 4 ohm load to the amp. But don't only want to send 150 watts to sub. Any help is appreciated. Thanks
if its a dual 2 ohm coil, yes
optimally, 500
depends on the box. if its ported, maybe. if its sealed VERY unlikely
optimally, yes
see answers in red above. as long as your amp puts out 500 rms at 1 ohm, then youre questions are valid and you should be good. Just be careful when pushing it too hard/low in a ported box and avoid clipping at all costs unless you want to blow the woofer
rb042hou
rb042hou
rb042hou
Mike Mccabe
    Jun 28, 2026
Giles
    Jun 27, 2026
