I haven't had any problems with the new baskets. Although, if you stress any sub past their designed limits, something will break eventually. It just happens to be that soft parts are the weak link on these subs.not even clipping it you can blow it. play alot of lower freqs alot see what happens to the spiders/triple joint. its a decent woofer and with a 1200aq you wont have a issue with it...
Well if you're dead set on tuning low, then yes, that sub will work better and handle the power. The default selection on everything else should be fine. Make sure you get D2 coils so you can wire your amp to 1 ohm.What should I select for the other options if I buy this? I'm not too familiar with sub design. So you think this would be a better option for me over the AB XFL or the AB HD?
He should absolutely no problems with cooling, p chamfer, and spider options added.I would not put 2k daily to an fi q
i'm not too familiar with the new ones actually....when they first came out and everyone had them I don't think they could handle that?He should absolutely no problems with cooling, p chamfer, and spider options added.
new ones are much beefier 1500rms stock with cooling and pf chamber you get 400-500rms added in power handlingi'm not too familiar with the new ones actually....when they first came out and everyone had them I don't think they could handle that?
