I have an American Bass VFL 150.1
Mechanical 10/10--Freshly Refurbished by AJR International in Glendale Heights, IL on 7/9/2012.
Cosmetic 7/10--Few scratches from mounting and use and it's missing the bottom plate and side plate with the aux inputs and bass controls.
Features/Specs
* I OHM STABLE D CLASS MONO BLOCK AMPLIFIER
* LOW LEVEL INPUT AND OUTPUT
* FREQUENCY RESPONSE: 20Hz~350Hz
* INPUT LEVEL: 0.2V~6V
* VARIABLE SUBSONIC: 10Hz~50Hz AT 24dB/OCT
* VARIABLE LOW PASS FILTER: 35Hz~250Hz AT 24dB/OCT
* VARIABLE BASS BOOST: 0~9dB AT 45Hz
* REMOTE GAIN CONTROLLER
* TWO AMPLIFIERS LINKABLE CONNECTOR AND SELECTOR
* FUSE RATING-200 AMPS, LINKED FUSE RATE, 400 AMPS
* EXTERNAL FUSES AND FUSE BLOCKS
* 2900 WATTS RMS @ 1 ohm
* Width: 9.5"
* Height: 2.25"
* Length:16"
$375/shipped
Item will be shipped from 45661, Ohio and insured.
Features/Specs
* Width: 9.5"
* Height: 2.25"
* Length:16"
$375/shipped
