American bass amps
juanmgarza26
looking into the amps, hoping the dealers can chime in for pricing,
I'm looking into the vfl 120.1 and PH4000MD
i saved enough little by little and bought a IA death row, want the extra 1000 watts to add another sub DR later, i really like the way the AB amps look, and their specs are pretty good, know ebay isn't always the way to go, would rather support a vendor here on the forum...
Is the aq and the 20.1 not the same dang board as the 120.1. I would talk to mylows10 and get u a new 120.1 it will do around about the same as the aq ia and sundown 2k don't know y dude thru the 1500 in there. I would only go with the ia if u wanted to match all ur stuff.
looking into the amps, hoping the dealers can chime in for pricing, I'm looking into the vfl 120.1 and PH4000MD
I can help you out. Just need a budget and how much power you want
20.1 is completely different and having the same board means nothing. My HFi 2500 has the same board as the mentioned amps if that tells you anything.
^^^ soo true.
Imagine your sytem like a desktop pc. It can have the same motherboard but you'll need fans/liquid cooling, video card, processor, power supply and everyhing else to determine the actual performance of the system.
With an efficient box 2 death rows will get really loud on a 120.1 and be easier on your electrical than a 150.1, might as well just get a 120.1 and call it a day... My 15" xsv2 is underpowered by a 120.1 but gets stupid loud cuz my box is efficient.
Sweet!! Id deff be interested in when that takes place. Hopefully a true Dyno @14.4 or less @ a true vehicle Voltage output? Rather than above...
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
985
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
juanmgarza26
juanmgarza26
McAllen, TX
juanmgarza26
    May 20, 2024
    May 20, 2024
