Am I going to overheat??
  • 2
dbaxter01
Pretty new at this so take it easy on me and help me out.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I'm running 4 Blaupunkt ODxa547's DVC 5x7's in the doors of my Sporttrac. I am currently running them with the headunit only, Aiwa CDC-MP3(22x4RMS) and only the full range voice coil.
I have purchased off Ebay a Profile California 440sx(50x4RMS @4ohms, 75x4@2ohms) that is stable at 2ohms. When I install the amp, I plan on wiring in the second voicecoil (woofer only) of each speakers, which will give them 2ohm loads.
My questions are this: I'm not planning on running this at huge volumes, but do I run the risk of overheating at fairly normal levels? Also, I have no current plans for a sub, but will running this system with both voice coils get me a fair amount of bass without a sub?
Any comments would really be appreciated!!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :)
You should be just fine. if you push 75 to four speakers it will really loud. Bc if you normally run 22w X 4, your about to double the power, and for highs you don't need that much power for them to sound loud. Which means your amp will be just fine becuase your using it's average output. it will over heat if you have the gain way up and the music blasting but i don't know to many people who blast their interior speakers that much.
i hoped this helped
latta
Thanks, I'm hoping that's the case. I'm not planning on really cranking them. At least not too often;)
The amp is going under a seat anyway so it should get fairly good ventilation.
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
Now you're annoying me because you are attacking me personally without addressing anything I've said. Show me a single post I've made that's...
20
4K
dbaxter01
dbaxter01
Atoka, TN
dbaxter01
    May 12, 2024
Brendon Jenness
    May 11, 2024
