Alternator/Power?
Ditch the caps. That alternator will be quite enough. Just upgrade the "big 3" wires, and if you want, replace the battery. (a group 31 batt ideally if you have the cash. Even a yellow top will do fine)
gettting a cap wont hurt when u have the alternator. But i suggest u get an optima red top or yellow top instead of the cap. if ur gona get a cap just get a 1 farad. no need for 3 farad.
the cap will not be needed with a proper HO alternator. Also, check out http://www.excessiveamperage.com Nate's 200 amp alts give 200 amps at idle. Read on his site, also his prices are lower...good alts. good luck, peace
NG
he told me his only puts out 100 at an 800rpm idle //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif anyways it's still a good alt. but i chose dom because he gives a little better warranty.
Im running a diamond d5 600.4 and a 1200.1 and was planning on getting the alternator for MR.Alternators
Hmm...just HOW necessary is an HO alt??
I'd say only necessary if you have plans to add more amps OR you just have a lot of money and want to spend it.
Otherwise - a 105A alt isn't exactly weak and SHOULD power those amps w/o a lot of trouble.
Well I can only turn my sub amp up 1/4 of the way with out it cutting out from power loss and I already have a Optima red top battery. My alternator only cost $270 for a 200 Amp Alternator so its not too expensive.
pheat3980
pheat3980
Altoona, Wisconsin
n2audio
