Alternator or Capacitor
Replace the alternator
Get a big car, like a caddy witha northstart engine. Somethign big and powerful
connect jumper cables right on the battery terminals.
Turn the caddy on
and put your truck on accessory
LEt it run for a bit
keeping the caddy accerated to about 1.5 rmps
CRANK your truck's system, if it doesnt bottom out.
Then you definatly need an alternator
No cap will help you.
If the same thing happens, it could just be your amp screwing its self in the poopshoot
who said they were a part of the charging system? if your alt is bad the battery or the cap will read weak because it isnt getting a charge... ................. batteries and caps dont make power they simply store it. what goes in comes out...crappy in crappy out...
) For those of you "In The Know" you will notice that this is the Exact Same Amplifier as the "Genesis" Amplifiers that are Dominating the Sound Off Circuits. That's because they are the same! Poweramper builds them for "Genesis"!
Originally posted by audiolife ) For those of you "In The Know" you will notice that this is the Exact Same Amplifier as the "Genesis" Amplifiers that are Dominating the Sound Off Circuits. That's because they are the same! Poweramper builds them for "Genesis"!
What does that have to do with Caps and charging systems?
I mean, it sounds interesting, but where did that come from?
take it easy,
-zane
actually now that you mention it... if that amp really sucks out 90 amps continually... that means alot of cars couldnt use it at all. my stock alternator puts out only 65 amps (honda civic). THe biggest alt i found was 135 amps for my car, which according to your math, still wouldnt be enough
Dooka4u4
Dooka4u4
PA
audiolife
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
