Alternator... is a 105A strong enough to run this amplifier?
hawk45
Tool
Have a alpine HU and just added a Profile AP1000M amp and sub. Week later alternator (at least I think) died. Car won't hold charge. Anyway... need to get fixed asap... local autozone has 105Amp alternators. Will they be strong enough to run this amp? Here are specs:
http://www.millionbuy.com/prfap1000m.html
Peak Output Power(4 Ohms): 650W x 1
RMS Output Power(4 Ohms): 310W x 1
Peak Output Power(2 Ohms): 1000W x 1
RMS Output Power(2 Ohms): 500W x 1
Bridged RMS Output Power(4 Ohms): N/A
MOSFET Power Supply
Total Harmonic Distortion:
Signal/Noise Ratio: 103 dB
High/Low Level Converter(Male RCA)
Pre-Amp(RCA) Outputs
Variable Bass Boost@45Hz: 0 - 12 dB
12dB/Octave Crossover: LP (Built-In)
Variable LP Crossover Frequemcy: 50 - 250 Hz
Variable HP Crossover Frequency: N/A
Bass Level Remote Control (16.4 ft)
Variable 12dB/Octave Subsonic Filter: 20 - 50 Hz
Variable Phase Control: 0 - 180¡Æ
Fuse(s): 2 X 30A
Dimensions (WxHxD): 13 5/8" X 2" x 10 1/4"
Power/Speaker Terminal Size(Gauge): 4/6
Thanks guys..
Oh yeah, I would say so. That's not a problem at all, the only thing is what kind of car do you have? Must have been a pretty weak stock alt for just that amp and hu to kill it, I mean it's not drawing major amps or anything at all.
I have a 99 Chev Blazer (S-10 Style). Everything was running fine yesterday till I went to lunch and battery light came on as I was driving. Came back to work and when went to leave (5 hrs later) all was good. Got in and started driving and radio began to shutoff. Would come back on in few seconds then go out again. So I popped off the faceplate and drove in silence for a bit. Put the face back on and got tunes up and running again. Started doing same thing. Battery light came on again. Got home and today... DEAD.. uggghh.
I tried jumping tonight when got home from work (took wifes car) and it started but was idleing really rough and all kinds of lights blinking. Turned off and tried to start again but no go..
Guess I will hit AutoZone with the battery tomorrow and get it tested and pick up an alternator.
how many amps does that amp draw at max power
Looks like 60 Amp fuses (30x2)
310W RMS/ 650W MAX = .47
.47 x 60A = 28.2A continuous draw
So if I figure a 105A alternator
105 x .40 reserve = 42A reserve
42A reserve - 28.2A continuous should be good correct?
try summit racing or jegs man...they should have a 140 amp unit for your car and that will be plenty. my alt is 63 amps stock and i upgraded to 140 with a yellow top and i'm running a mean machine 1400.1 and a mean machine 100.4 with no problems what-so-ever.
I have a 105A alt in my blazer and my amp is 500x1 @ 4ohm i have a regular battery..i have no problems my volts stay at 14.4
Looks like 60 Amp fuses (30x2)310W RMS/ 650W MAX = .47
WTF is that??
Dividing rms power by peak power has nothing to do with current draw.
You're just running one 4 ohm sub?
If you want to figure current draw it works like this...
310w/.6 (60% efficiency) = 517w
517/~14v = 37A = full power test tone current draw
Typical music crest factor is at most 1/3 rms-to-peak power so for music you're looking at no more than 15A to play music LOUD.
IMO 105A should be enough alternator to run 2 of those amps at 2 ohms.
WTF is that??
hmmm
i wonder what my 115amp alt and my orion1200 will do
80
that sounds like a good idea if you can afford to wait for shipping, but you should have no problems running that amp
we happen to live in ohio...so shipping isn't really an issue as long as they have the part in stock. Hell i live an hour form either one of them so if i need it sooner i just drive.
Hmmmm. I have a 105Amp alt and I run a Hifonics BX1500D and a Alpine MRP-240. I get minimal volt drops and my car runs fine. NO problems. I also Have seat-heaters and a hotshot that draws 60amps of current when on. I can run everything without a problem.
I'd just get a replacement alt. (105A) or if you have the money upgrade to a 140. Doesn't hurt at all.
hawk45
Tool
hawk45
Cincinnati, Ohio
hawk45
