Alternator help
I have infinity speakers and subs.the subs max out at about 950 watts. I got a 5000 watt amp but I am not sure on what alternator I should purchase. I have a 2002 Grand Prix gt with a 3.8l v6. I cans spend about 170 or so on an alternator. Thanks in advance
Well i doubt its a true 5000 rms amp what amp and model? and u arent gona find a decent alt for 170...all the good companies will be around 350-500 ..depending on the power that amp does id say a good agm battery or 2 would do fine
The amp does about 300 rms when bridged. I need a new alt regardless but don't need one that's huge.problem is when I turn up my speakers my lights dim pretty badly.
300rms and the lights dim bad? id say the alt and or battry is shot ...just get a stock alt and a good agm under the hood and u will be fine
SAME THING HERE. HOW TO GET THE RIGHT ALT. I GOT 2 8sa sundown with a arc audio 2000 amp at one ohm plus all 4 speakers with a ppi 800 not sure everything is run from the battery with 0 gauge then to 4 gauge. i got the big 3 with 0 gauge. so what kind of alt so a i get or what brand? thanks for the help
02grandprix
02grandprix
Louisville
el_papagallos
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
