alt power? lol
from answers.com
IF you remove the right front tire and guard this will give you easy access to your alternator. You will need to jack your car up. It sits underneatdh the engine to the right of the starter. If you locate the oil filter you'll see it right in front of you. Just disconnect your battery and then the pplasitc guard on the alternator held on by a single bolt. Then disconnect all wires. Next, Unscrew the two bolts that runn across the bottom. Put a 14mm on the tensioner to put some slack in the serpentine belt and pull the 14mm wrench. Take the belt from around the alternator and then remove the bolt on the top right of the alternator. that one in particular is a little hard to get to, but take your time and good luck. I f you are still having trouble then get the Haynes Repair manual for the Saturn S-series 1991-2002. You can find them at any auto perts store and they are great to have!
im not looking to remove it, just to be able to do the big 3
I can't believe noone's said it yet...
Do Not Jack On Your Oil Pan Or Your Brake Lines!!! lol
---------- Post added at 09:47 PM ---------- Previous post was at 09:46 PM ----------
everyone know someone who knows someone that knows ***** about cars.....
I can't believe noone's said it yet...Do Not Jack On Your Oil Pan Or Your Brake Lines!!! lol
I jack my bike up on it's oil pan all the time...
If you run the power wire from the Alt to the AC compressor than to the battery it will help the amp run cooler when you have the a/c on
09civic
09civic
Melbourne, FL
SoCalNoob
