RRR37
I am trying to push my 2 12" Pioneer champion TS-W308D2 (400rms) at 2ohms from my Hifonics BXi 1606D. My HU is a Dual XHD 7714 (I know, I went cheap but the options are awesome for the price). I am also running 4- 5x7" Soundstream PCT.573's (3ohm) on a Memphis 16-SE 2.50.
My wiring:
I have my HU wired standard to the wiring harness and the remote wire going to the amps. I have run the rca's (sub out to hifonics)(front out to Memphis) up the middle of the vehicle as to avoid running with the power wire. I am running a 6ga. power cable from the batt.+ down the drivers side to the 1 farad cap (cheap Fry's model) then to terminal block which feeds the amps all 6ga. wire. the amps are both grounded with a 4ft. piece of 4ga. which is bolted to a sanded area under the carpet in the back. The capacitor is also grounded to the - in a different spot in the same area of the car. To avoid trying to fit wires through the tight openings on the doors for the 5x7's, I left the stock wiring in place and ran 16ga. from the wiring harness at the HU to the Memphis in the back with 2 speakers wired to each channel. I think that's about it on wiring.
The problem:
When I wire the pioneers at 2ohms the music is cutting as the bass hits at high volume. The volume goes from 0-46 and when I hit about 28+ it starts cutting in and out with the bass. The power cap also jumps up and down in voltage from 12-14 and the lights dim with the bass. I have 2 old kicker impulse 10's (8ohm) that I have tried, wired at 4ohms and they don't cut out but hit nowhere near as hard as I want. I have tried different areas for grounding to make sure the connection there is good. I have gotten another 4ga. and run it from the batt. to make sure that the 6ga. wire is not the problem (I know I need more and am saving to go all 1/0). I have ran without the hifonics to make sure that the memphis and soundstream combo is not the problem. Could it be that when I go to 2ohm I am trying to push too much power for my alternator? Could my battery be getting too weak? I have not yet done the big 3 because I am waiting to get a bunch of 1/0 to run everything with (that stuff is expensive).
Obviously I am not very experienced in car audio yet. I have put in a few rag tag systems but nothing major. This is the first time I have come across this problem. I am new to the forum so if there is anything I missed on how I posted, please let me know so I can post correctly. Any advice on my problem would be greatly appreciated.
Thanks
My wiring:
The problem:
Thanks
