alt power? lol
A jack? You don't know anyone that owns a freaking floor jack? Go to Harbor Freight and spend $20 on a tool that I guarantee you'll use enough times to get your money's worth.
from answers.com
IF you remove the right front tire and guard this will give you easy access to your alternator. You will need to jack your car up. It sits underneatdh the engine to the right of the starter. If you locate the oil filter you'll see it right in front of you. Just disconnect your battery and then the pplasitc guard on the alternator held on by a single bolt. Then disconnect all wires. Next, Unscrew the two bolts that runn across the bottom. Put a 14mm on the tensioner to put some slack in the serpentine belt and pull the 14mm wrench. Take the belt from around the alternator and then remove the bolt on the top right of the alternator. that one in particular is a little hard to get to, but take your time and good luck. I f you are still having trouble then get the Haynes Repair manual for the Saturn S-series 1991-2002. You can find them at any auto perts store and they are great to have!
09civic
09civic
Melbourne, FL
SoCalNoob
