Alpne CDA 9887 with KTX 100eq IMPRINT
  • 5
I just tried it again and done the compatibility thing and it said it installed and everything. SO i click on it and it says the same thing. Now does the imprint have to be hookd up in order for the program to come up.
Cause at the bottom it says port open error. DOnt really know what that means. So i though since the imprint isnt hooked up to the laptop yet then it wont come all the way up.
You have to have it hooked up fully with the car in accessory mode for the app to even open.
I have a 9887. You dont need an EQ or line driver. The 9887 has active capabilities and 4v preouts.
2v at max i tested outputs... maybe if you boosted it to hell it would be 4volts.
I personally use a Audiocontrol line driver on my sub preout for this very reason since I don't play my music Maxed out and the sound is a great improvement.
Also, about the voltage being adjustable!? I've never heard of this and been through my manual a million times... care to specify what you're talking about?
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
999
That’s really helpful, thanks! I’ll keep digging and see what I can find online :)
I'm hoping to find someone who might be able to repair this head unit. The faceplate doesn't slide out at all.
beat-down69
beat-down69
Buffalo, KY
beat-down69
    Jun 1, 2024
    May 31, 2024
