Alpine type r amplifier question
90 I believe. I have 0/1 power and ground wire for the amp. Just a get by car until tax time. My box is a huge slot ported box. 4.25ish cubic foot.
90 amps is low man mine is 125.. u can try it maybe upgrade battery to a agm under hood if u haven't and get big 3 wires under hood.. see how it does with either new agm or big 3 set gain low still be more power than u had even not using full power of amp.. biggest problem maybe headlight dimming..
If I was you and $250 was my budget and I had 2 type rs I’d try to find a used jl 1000 / original or v2. Very efficient clean just test it fully before buying or buy from an experienced eBay seller
The slash amps are terrible efficiency. It’s in the designs. RIPs is constantly pulling current. They even recommend alternator upgrades for the 1000
If 687 watts @1.6ohms and 141 amps is “terrible” for the 500/1 you need to put down that crack pipe
I’ve had 7 slash amps. Not talking out of my ***
It’s the same thing with the RF CP amps. Any tightly regulated amp
Btw. 141 amps for 600 watts is terrible.
I’ve had 7 slash amps. Not talking out of my ***It’s the same thing with the RF CP amps. Any tightly regulated amp
yeah i'm running over 1000rms on a 125amp alt so i wouldn't even be able to run that jl 500..
I am curious as to ask if you even tested your subs at all to see if they are not blown or if either have a bad coil and sending that amp into protect mode before ruling that amplifier as the culprit?
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
690
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
I would just go with a ported box tuned from 32 hz. - 35 hz.
Mellowmatt92
Mellowmatt92
Arkansas
audiobaun
    May 31, 2024
    May 24, 2024
