Alpine No sound for aux, bluetooth, usb
kalij
I installed an Alpine UTE-42BT into my 2006 Pontiac Pursuit G5. I have sound for tuner, but not Aux, USB or Bluetooth.
Could this have something to do with amp (blue/white) wires? Where did I go wrong? Which wires am I supposed to hook up?
Thanks so much.
I am having the same problem. The unit is a Pioneer AVH-P4000DVD and I get sound from the radio but not the aux, usb, or ipod connection. There is a hissing/fuzzy noise when I switch it to aux mode and ipod connection. The ipod connection reads and plays the ipod but there is no sound. It won't let me post pictures probably because I am a new member but I have the blue/white wire from the radio harness connected to the blue wire from the car harness. There are no other wires to connect to except for the green parking brake wire and the yellow mute wire.
Sometimes my pioneer does the same thing. The best solution is to unplug and re-plug my iPhone. Could be a bad unit too. Make sure you are using the right Pioneer cable, some of them are finicky without the Pioneer branded cable. I'm selling mine because I got an iphone 5
I've had my radio for a few years with the same ipod touch in 3 different cars and this is the only car that has this problem. The only difference is that I am using an aftermarket pioneer radio harness instead of the original one because I lost it. I would try to re-wire it so the amp turn on matches with the amp turn on but there is only one (blue/white) amp turn on wire
I'd take the Morel Maximo 6 over anything on your list.. 169.99 or so from Crutchfield.
23
7K
104
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
362
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
kalij
kalij
Calgary AB
seto19
    May 12, 2024
Brendon Jenness
    May 11, 2024
