all sorts of questions on newly installed system
frankiebones
first things first; until today, I had never even touched an amp.
there are many terms I don’t understand, but since I have about 9 days and 6 hours until my second year law school exams, I was hoping you guys could help. I have an alpine 9856, which needs tweaking. also, the levels of my amps need tweaking. I keep having my 4 channel shut itself off when I go loud (but not as loud as it went without the amp and components). furthermore, I cant use alpine’s website to get the proper settings because my head is not yet listed and I didn’t see one that was comparable.
some info on the alpine 9856:
Bass Engine: Bass Engine functions provide control over your system, so you can tailor the sound to your personal tastes. Bass Engine includes the following functions:
• Bass Control:
o Bass Center Frequency: Select from 60Hz, 80Hz (default), 100Hz, or 120Hz
o Bass Band Width: Select from 1 (narrow) to 4 (wide)
o Bass Level: Select from -7 to +10 (-14dB to +20dB in 2dB steps)
• Treble Control:
o Treble Center Frequency: Select from 7.5kHz, 10kHz (default), 12.5kHz or 15kHz
o Treble Level: -7 to +7 (+/-14dB in 2dB steps)
• Defeat On/Off: You can reset the unit to its factory default bass and treble settings by turning the Defeat function on.
Bass Engine® Sound Tuning
• • Subwoofer Level Adjustment
• • Bass Center Frequency Control
• • Bass Width Adjustment
• • Bass Level Adjustment
• • Treble Center Frequency Control
• • Treble Level Adjustment
General
• • 50W x 4 High Power Amplifier (Micro Dynamics ™)
• • CD Changer Control Function
• • Flip Down Face
• • Rotary Encoder Volume Control (Pop-up Rotary Knob)
• • Black Face w/Blue illumination Buttons
• • 3 PreOut (2V PreOut)
• • Bluetooth® Ready
• • BBE Processor
• • Versatile Link Ready
• • MM Driver Ready (Hard Disc Drive Ready)
• • Media Playback
• • Separate Bass & Treble Control
• • Fader & Balance Controls
• • S.T.M. (Source Tone Memory)
• • Clock
• • Detachable Trim Plate
• • Anti-Theft Detachable Front Panel
• • Dimmer-on Input
• • Power Antenna Lead
• • Remote-on Lead
• • Audio Interrupt In
• • Wireless Remote Control Ready
• • Demo Function
• • Audio Mute
SPECIFICATIONS
FM Tuner
• • Tuning Range: 87.7-107.9 MHz
• • Mono Usable Sensitivity: 9.3dBf (0.8 µV/75 ohms)
• • 50dB Quieting Sensitivity: 13.5dBf (1.3 µV/75 ohms)
• • Alternate Channel Selectivity: 80.0 dB
• • Signal-to-Noise (S/N): 65.0 dB
• • Stereo Separation: 35.0 dB
• • Capture Ratio: 2.0 dB
AM Tuner
• • Tuning Range: 530-1, 710kHz
• • Usable Sensitivity (IEC Standard): 22.5/27.0 (µV/dBf)
CD Player
• • Sampling Rate: 44.1kHz
• • Signal-to-Noise (S/N): 105 dB
• • Frequency Response: 5-20k ±1 dB
• • Horizontal Resolution: 500 Lines or Greater
• • Channel Separation (1kHz): 85 dB
• • Dynamic Range (1kHz): 95 dB
• • Total Harmonic Distortion (THD): 0.008% (at 1kHz)
• • DAC Type: Regulated 1-Bit
• • Oversampling: 8X/352.8kHz
• • Wow & Flutter (%WRMS): B.M.L.
• • Subwoofer Level Adjustment Range: -15dB to 0dB (1dB steps)
• • Bass Center Frequency : 60Hz, 80Hz, 100Hz, 120Hz
• • Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
• • Bass Level Control Range: +20dB to -14dB at 60Hz (2dB Steps)
• • Treble Center Frequency: (Selectable) 7.5kHz, 10.0kHz, 12.5kHz, 15.0kHz
• • Treble Level Control Range: ±14dB at 10.0kHz (2dB Steps)
• • BBE® Modes: On(1, 2, 3)/Off
Dimensions
• • Din Size: 1
• • Chassis Size (W x H x D) mm: 178mm x 50mm x 162 mm
• • Chassis Size (W x H x D) in: 7" x 2" x 6-3/8"
• • Nose Piece Size (W x H x D) mm: 170mm x 46mm x 19 mm
• • Nose Piece Size (W x H x D) in: 6-3/4" x 1-13/16" x 11/16"
General
• • CEA-2006 Power Rating (4Ohm@14.4 V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 18W x 4
• • Max Power Output: 50W x 4
• • Pre Output Voltage (Before Clipping): 2V
• • Power Requirement: 14.4 (11-16) V.DC
• • Operating Temperature ( °C/ °F): 60°C (140°F) to -10°C (14°F)
• • Maximum Mounting Angle: 30° from Horizontal
• • Weight: 1.6kg (3lbs 8oz)
2 pairs of pioneer ts-c160r components:
Outboard Crossover Network-12dB/Oct. HPF and -12/Oct. LPF, Tweeter Protection Circuit and Tweeter Level Adjustment (0,-3dB) Full - Depth BasketFor Rich Bass Response (Aluminum Die-Cast) Gold Plate Binding Posts Specifications Watts MAX. Music Power250 Watts Watts Nominal Power Handling60 Watts Frequency Response25Hz ~ 32kHz Sensitivity90dB (1W/1m) Ohmn Rating4
powered by kicker kx650.4
alpine swr-1042d:
Kicker KX650.4 (more than enough power obviously but I will keep it far from cranked)
» 4-channel car amplifier
» 120 watts RMS x 4 at 4 ohms (170 watts RMS x 4 at 2 ohms)
» 325 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
» cooling fan
» 2-, 3-, or 4-channel output
» CEA-2006 compliant
» Tri-way capable (Tri-Way Crossover required)
» speaker- and preamp-level inputs
» variable front & rear high-/low-pass crossovers
(variable 50-200 Hz, 12 dB per octave)
» variable bass boost (0-18 dB) centered at 40 Hz with wired remote control
» three-way protection circuitry
Single 10" Alpine Type-R SWR-1042D
» 10" 4-ohm subwoofer with dual 4-ohm voice coils
» Kevlar-reinforced pulp cone with Santoprene rubber surround
» cast aluminum frame with perimeter venting
» frequency response: 26-600 Hz
» power handling: 200-500 watts RMS
» peak power: 1,500 watts
» sensitivity: 83 dB
» top-mount depth: 6-7/8"
» sealed box volume: 0.5-0.8
» ported box volume: 0.6-1.3
Enclosed in a Q Logic QLH-1.0010SE sealed box. (1.0 of space)
Pushing the sub, I have a Kicker KX400.1 mono amp.
» 200 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
» variable low-pass filter (50-200 Hz, 12 dB per octave)
» variable bass boost with wired remote (0-18 dB at 40 Hz)
» switchable subsonic filter (12 dB/octave at 25 Hz)
» preamp outputs
Kicker KX400.1
» mono subwoofer amplifier
» 200 watts RMS x 1 at 4 ohms (400 watts x 1 at 2 ohms)
» variable low-pass filter (50-200 Hz at 24 dB per octave)
» variable bass boost (0-18 dB at 40 Hz)
» subsonic filter (12 dB at 25 Hz)
» wired remote bass level control
» Class D design
» speaker-level inputs
» preamp inputs and outputs
» fuse rating: 40A x 1
I need to know what settings I should do for the whole thing, defeat, BBE, everything. it sounds better with defeat on, but then it sounds like the woofers are making bass, when they shouldn’t be. please help, now back to constitutional law (my stereo is my only release)
frankiebones
frankiebones
NYC
frankiebones
