Alarm Duration (Need FAST response PLZ!)
The siren duration can be changed to 60 seconds without a bitwriter.
Open a door.
Turn the key in the ignition switch on, then off.
Press and hold the valet switch.
After a moment, you should hear a chirp. Continue holding the valet switch until you hear a double chirp.
Release the valet switch, then press and release it once, then press and hold it again.
You should hear one chirp.
Press and release the unlock button on your transmitter. You should hear a double chirp.
Turn your key on and off again to exit the programming mode. You'll hear a long chirp.
xpl0it
xpl0it
everywhere
Shyne151
