HighlanderAudio
hey guys, been a while.
I'm having a strange issue.
I installed an aftermarket radio/gps/backup cam in my wife's vehicle. It had no issues for about 2 weeks. Out of nowhere, it wouldn't power on. Checked the radio fuse (25a) under the hood and it looked to be fine except it was corroded with a thick white film. Cleaned the fuse socket and replaced with new 25a fuse.
Radio was working fine again for about 2 weeks. Then yesterday and today, I've had to pull the fuse and put it back in (same fuse, not replacement) for the radio to work again.
I'm not at all sure what the issue is. The fuse tests fine and has a SLIGHT layer of white film.
What could be causing the radio to turn off like this? If it is indeed the slight white film on the fuse connections, how do I fix this? Will dielectric grease on the fuse legs work, then plug it back in?
Do you guys think there's an issue elsewhere?
Friend of mine mentioned I might need a bigger fuse, but I'm worried about messing up the electrical with a higher Amp fuse if something were to go wrong.
Vehicle: 07 Toyota Highlander (non nav stock)
Radio: Boss Audio BVNV9384RC with nav, GPS, backup cam.
I know Boss Audio isn't great, but it works for our need perfectly...when it stays on lol.
