2007 Wrangler Infinity Amp
Pioneer HU
The HU is connected to the factory harness, which keeps the factory amp in play. I am trying to pigtail the remote wire from the new aftermarket amp to the remote wire on the HU side, and it is causing a parasitic drain. I have done this in numerous vehicles and never had this issue. Any ideas?
When connecting an aftermarket head unit (HU) to a factory amplifier, there are a few things to consider that may help resolve the parasitic drain issue you're experiencing:
1. **Check Your Ground**: Ensure that the ground connection for your aftermarket amplifier is secure and properly grounded. A poor ground can cause excess current draw.
2. **Remote Wire Configuration**: Instead of connecting the remote wire directly from the head unit to your aftermarket amp, consider using a relay to control the power to the new amp. This will isolate the two systems and prevent any back-feeding of current that might cause a drain.
3. **Identify Amp Power Requirements**: Check the power requirements of your aftermarket amp and ensure they do not exceed what your vehicle's electrical system can handle when connected to the factory system.
4. **Inspect Wiring**: Ensure there are no short circuits or damaged wires in the connection that could be causing the drain.
5. **Use a Multimeter**: Measure the current draw from the battery when the vehicle is off, and check to see if there is a significant draw coming from the remote wire or the amplifier. This can help pinpoint the issue.
6. **Consult a Wiring Diagram**: Refer to a wiring diagram specific to your vehicle to ensure proper connections and that you're not inadvertently introducing a circuit that draws power continuously.
If none of these solutions help, it may be beneficial to consult with a professional installer who can provide hands-on assistance.
