aftermarket head unit with stock dvd
  • 2
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
710
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
886
Brhyno
Brhyno
United States
matt_bennett05
