Aeroports make no sense!
Why do people say "you need two 6" aeros" but don't specify the length??? I could have a mile long 6" aero and it fits that sentence........ Also every calc I've used says all I need for a 7 cube box is a single 6" aero about 7" long which is obviously wrong. What is going on? I know I need about 16" squared per cubic foot and I want a 32hz tuning.
Pair of 6" flared ports would be about 18" (17 plus about an inch extra that accounts for the flares) to get 7 cubes tuned to 32hz. It's exactly what I run actually, two 6" flares, 7 cubes net at 32hz.
And if you had only one 6" then about 7" long is correct. That's not a lot of port area though, unless you're running low end subs with not a lot of power.
How do you figure out how long they hafta be?? I'm planning on 2 aeros.
im really surprised no one else(that has exp with aeros) said this but instead of doing 2 6" aeros, i would do 1 8" personally. Less ports are more efficient then then multiple. Both 2 6" aeros and 1 8" roughly equal the same amount of square inches.
Example:
2 6" Aeroports = 56.52 square inches
1 8" Aeroport = 50.24 square inches
yes the 2 6" has 6 more inches but the single 8" will make up for it and more due to its efficiency.....
also 1 8" aeroport for 7 cubes net, to tune to 32hz the port needs to 13.04 inches long //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
So how does port area effect the bass? I've always heard more port area is a good thing. I'm running 2 15" subs with a RUB2500.
Lower port area will play more flat and have less roll off. Prefered for more sound quality
Higher port area will have more output but at a smaller bandwidth, peaky.
coolername
coolername
Bellingham, WA
LosIsATool
