Aeroports can decrease port size by 50%???
It has to do with port noise.
The reason many people use slot ports is to get a large area, to minimize noise. With Aeroports, they are smoothed to reduce turbulence, thus allowing for better air movement without noise in smaller ports.
I dunno about 50% smaller, but it does make a difference.
i know george...just trying to open this up for discussion without cluttering up the guys thread. I've thought for a long time that aero's would help reduce sq in of port but mathematically i can't prove anything
check out the link bro. devildriver (aka punkorama) mathematically showed a redution of vent velocity by 56% by using aero ports.
so in essence, in his example, you can get by with 56% less by using aeros.
so let me get this right? u can use aero ports and have less air space taken up inside the box, while minimizing port noise and retaining sq?
o ****.... if i read it right. i need to get me some aeros soon =]
i saw that =[. so what rule do u follow for aeros? i no that height of port x width = 15.5 - 16.5 x (desired net volume of box that driver will see) in order to get ur needed surface area? how do u no if u need a 3" aero or 6" aero?
mike-
I posted a link that has the mathematics in it in the other thread.
is there a chance you could possibly post it again, im rather interested in this.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bonesninja
bonesninja
Lima, Ohio
IgnoreMe
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
