Aeroport Questions
ascitiesburn69
Ok guys i plan to get a hdc3 12" and an AQ 1200d to push it. Box is planned to be ~2.4cuft after displacement @38hz. I planned to use aeroports to be able to keep the box a tad smaller. Is it better to use more than one aeroport in this situation? I plan to use one 4" aeroport @5.6" however that is the calculation for a round port without the flares. So what would the length need to be for an aeroport including the flares if i used a 4" diameter one. and could someone explain how to figure this out? And also what the length would have to be with 2 aeroports? And also Whats the best place to put them IE: on one side of the box on top of one another, side by side, one on one side of sub etc..
Thanks alot
I did but i was wondering how many to use etc? and also someone to explain the installation process because i read the instructions and it's kinda like wth? all the cutting straight piece 5" shorter etc
Ok so if im using 2 4" aeroports in a 2.6cuft box with a desired tuning of 38 it requires 15.11 port length so with aeroports it should be 16.11 so with 2 4" each "aeroport" each one would be ~8.05" ?
ascitiesburn69
ascitiesburn69
New Orleans, LA
ascitiesburn69
