Aero Ported IDMAX 12. Please check my design before I build it :)
magictoilet
Vehicle: 01 Lexus GS430
Sub: IDMax 12 v3 d4
Amp: Alpine PDX-M12
Volume: 2.55 cu ft.
Freq: 28 Hz
Box Design: 30" width, 13" height, 15" deep (can change), Aero ported box. Sub facing up, 2 4" aero ports facing up, both 7.5" long
Going to put a .5" acrylic window in the front to see sub and leds inside, leaving at least 2" of wood/window overlap, drilling screws at the 1" edge, every 2" down the window. Look at pics for details.
I'll put silicone sealant between the wood and face, then going to put another piece of trim in front. Anything I'm overlooking?
I guess I'm wrong that I can't just halve the 15" length into two 7.5" ports. Thanks for correcting me! I can't fit a 15" tube in my box though since it's only going to be 13" high, is there any way around this besides a slot port (I want tuneability with the aeros)?
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
magictoilet
magictoilet
San Diego, Ca
ax600
Decebal
    Jun 10, 2024
