Aero Port size / Port noise
ZEROohms
Hello,
I'm looking to build another enclosure for my GMC crew cab, since I've been experiencing alot of port noise with my current enclosure. Due to the lack of space (located center console) I'm thinking an aero port will be the best.
I have a gross volume of 1.55 cu.ft.
Subwoofer - RE Audio SX10
Amp - Boston Acoustics GT-2200 (900w @2 ohms)
I'm wondering if i should go with a 3" or a 4" aero port. It seems like the 3" would be the more reasonable option for the space, ~12" port length when tuned to 32hz, as opposed to the ~24" port length with the 4" tuned to 32hz.
With this box, I do not want to experience any port noise. What would you guys recommend?
Thanks,
Brian
This is the current box, I would like the new box to stay within the same footprint.
With a flared port, the box will be noticeably smaller than the one you currently have.  Whenever I make a ported box, and spacing is limited, I use flared ports instead of the conventional slotted port design. You should be fine with a single 3" port.
http://www.psp-inc.com/tools2.html
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
909
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
633
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
787
ZEROohms
ZEROohms
United States
THATpurpleKUSH
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
