Advice requested for new car system
NNVA11
I plan on having a shop, probably Go-Ho Audio, install a Sub Enclosure in a 2012 Mustang with audio gear that I already own: 2 "12 Kicker CVX dvc 2-ohm, Rockford Power T1500.1bd amp. They had previously installed the above in a sealed enclosure in a '02 Mustang back in 2007, but Hurricane Irene flooded lower portion of the car.
The new Mustang has about 2 cubic ft more trunk space than the old '02 had so I'm wondering if I should go with a ported enclosure this time around...if possible to fit it in the trunk? Would ported make a huge difference in bass over sealed? I listen to Rap/Reggae/Rock/Metal. I realize that I will have to sacrifice spare tire well space for amp and/or Optima Yellow Top battery.
Another issue is the headunit. The car has the Shaker 500 w/o Navigation/no electronics package. I would prefer to the keep the stock one so I retain Sync funtionality and I assume a line out converter is necessary such as JL Cleansweep or Rockford 360? Could 2 amps be run from the Line Converter if I add one in future?
So far I have replaced the 4 interior speakers with Pold db571's, and have kept 8" door subs stock for the moment. Any advice on good subs that will fit doors is welcome.
not sure of the sub depth ,but will keep an eye out,cuz i have an 07 stang also with a shaker 500 system.i've got a single dd 3512 in a big sealed box about 2.5 cubic ft ,and an arc audio kar 1000 and the wife loves it.http://www.termpro.com/memberalbum/71153B5.jpg
NNVA11
NNVA11
Newport News, VA
mylows10
