Advice on these two speakers
Hey I'm looking at purchasing a new set of speakers for my 02 Dodge Dakota. And I can't decide between these two speakers I'm just wanting your opinion on what might sound better. These will be externally amped by a 4 channel amp rated at 100w rms x 4
MB Quart PVM116 coax
Or
Kicker CSS674 component
The truck factory speakers are 6 3/4" but I could easily make the MB quarts fit if they will sound better
Thanks for any input you have!
I'm looking for clarity and crisp clean sound. I want a high quality system that will recreate live acoustic music such as jazz or orchestral. With a great sound stage. I know components have the upper hand on that but if the MB quarts are better quality with reproduction then ill go with them. I listen to a lot of different music mostly classic rock and underground hip hop. But I enjoy everything. I have a 12 band parametric equalizer to tune it to my liking as well. The system will be paired with one 10 or 12 inch sub in a sealed box too.
Between those two choices I wouldn't expect stellar results, even with an amp on the speakers and that equalizer at hand. With component speakers it matters where the tweeters are placed and aimed. Where would you put them?
Very true. It's just what the budget can afford haha. if you think another set between the $100-150 range would sound better, I'm open to suggestions. The front tweeters would be mounted on the side view mirror cover. So they would be aimed more towards the listener. And the rear would be towards the upper rear of the door panel. Possibly the c-pillar facing towards the front.
Also I just realized MB quart has the same speakers in component form haha
MB Quart PVM216
This is good.
This I don't like so much. Stick with coaxials for the back and fade the sound toward the front or put more money into the front speakers.
The PVM216 components look quite nice. I have a couple of options in that price range.
I was just thinking about that. theres really no need for the components in the rear. Ok so I'm thinking the MB quart coax for the rear and the MB components up front? That would offset the higher price too.
I like this idea //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nate88
Nate88
Fort Collins, CO
trumpet
