Good 5.25 speakers?
What are some good 5.25 speakers? I would need four that I'd be running off my pioneer head unit. I would also be running a single ab xfl 15 on 1000 watts if that matters. I wouldn't really need much bass if any from the 5.25 speakers, I'd just be looking for clear sound.
If your getting aftermarket speakers, your best bet is to get at least a small amp for them. Head units do not put out enough clean power. Often times aftermarket speakers will not sound as good as stock speakers on head unit power. Also, it is difficult to recommend speakers without a budget, or goals. What sounds good to someone might sound like crap to the next person.
Interesting, I didn't know that. I'm looking for cheap speakers pretty much. I basically want them to be able to play treble that I can hear over the sub bass.
A lot of guys who played with Morel Maximos said the sensitivity is high, so they might do well on head unit power. Most of power consumption happens at lower frequencies. Considering the 5.25s start to run out of steam at 100Hz, if you set the high pass crossover at 100Hz or so perhaps they won't be as starved for power. Don't expect miracles though.
Trumpet has an awesome price on a PPI 2 channel amp that could power four of the Bravox or Aura closeout coax on PE. The investment would be under $200 but you would have the output clarity and volume for your needs.
Take this man's suggestion on the the PPI amp from Trumpet. Great deal
razaice
razaice
Detriot, MI
black05alti
