Advice on Phoenix Gold R8.0:1
Is this a good amp?
Phoenix Gold R8.0:1
If so will it work good with my Subs
POLK AUDIO DB212-2 TWO DB124 12"
2 - 12" Diameter (30.48cm) Woofer
20Hz-200Hz Frequency Response
2 ohms Impedance
720 watts RMS power handling
1500 watts peak power handling
103 dB Efficiency
if those subs are anything like the dx series they made they will eat every bit of 400 rms and more (each) than they were rated for. i was running almost 500 rms to each of my dx's and they needed it because of the .88 per side sealed box they were in. id shop a little more if it were me. id look for an amp that does 900-1000 rms at the required ohmage.
The Octane R8.0:1 is rated 500wrms at 2ohms and 800wmax so you'll be getting like 250rms for each sub.
try to get a different amp.
nickdescending
nickdescending
San Diego
Cbass
michigan born
    May 14, 2026
michigan born
    May 14, 2026
