advice on a TYPE-R???
Originally posted by Hurst421 I have an amp that is 2ohm stable and alpine 2 type-r's tha are 2 ohm dvc each. Do i need o wire them any special way so they are 2 ohm when used.... or just wire them regular???
Again, people posting without giving enough info!//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
You say that your amp is 2 ohms stable, but what type of amp are you talking about?
Most mono amps are 2 ohms stable, and if that is what you have, then you can wire them up either series-parallel, or you can wire them up parallel-series. Both will give you a 2 ohms load.
If your amp is a 2 channel amp, then they are usually only 2 ohms stable when ran in stereo. In this case, you are out of luck, cause you can only run each of your subs at 1 or 4 ohms.
Most 2 channel amps are not stable when bridge at 2 ohms. If however, yours is, then again, you can run it either way that I had mentioned aboved.
Come on people, start giving us more info when you need help, we aren't mind readers!//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Hurst421
Hurst421
Hershey,PA
F.A.M.
