Advice on 4" components/How difficult for a first time installer?
you should find out what model those polks are. and find the power rating. then you could amp the speakers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i finally amped mine and I'm liking it alot.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
So two people here gave you good advice on where to get good wires for cheap, but then you spent twice as much and you still don't have RCA's?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Normally I would say you should have no trouble intalling it yourself if you follow the advice here, but since you don't seen to want to follow our advice I predict you may have serious problems trying to do this your self.
Good luck, you'll need it. Try not to burn down your car.
I got some RCA's yesterday so I have everything I need. The f*** you so mad for dude? I appreciate everyone's advice but I figure Kicker amp, Kicker subs, why not go with Kicker wires.
you should find out what model those polks are. and find the power rating. then you could amp the speakers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifi finally amped mine and I'm liking it alot.
I'll probably end up taking pictures to see if I can find someone to identify them for me.
knukonceptz is amazing wire for the money.....thats what im running.
but anyways, my freind and i (we were inexperienced with car audio installations at the time) put his system in and didnt run into too many problems. Just make sure you disconnect the negative battery terminal on the bat before you do anything. Just look up some directions online on how to install an amp and follow that.
But you should be fine...just take your time and do it right the first time around
JTriz87
JTriz87
757, VA
atlbraves
