Lexicon740iL 10+ year member
AGM FTW!
I'd like some education from you guys on how to tune my new install properly.
Here is the setup > http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/569181-06-bmw-x5-stage-1-adding-subwoofer-monoblock.html
The Audio Control instruction says to turn the accuBASS threshold potentiometer on the side of the unit all the way up if there is no problem will bass roll off and you want the full range of adjustment through the level controls on the top of the unit. I'm assuming I fit this category since my head unit volume can go all the way up with really no noticeable distortion from my speakers.
So now I have 3 settings on the top of the unit. accuBASS - Main - Bass
I am using this on just the single monoblock so I connected my RCA's to the bass output RCA's per the audio control diagram.
Since the main output RCA's are unused and for a full range signal I'm assuming the dial for main will be unused/unadjusted.
Now I need to figure out how to set the proper level on the LOC for the correct output going to the amp.
This will be achieved by adjusting the Bass dial on the top of the unit I assume because I'm using the RCA's connect to the bass output to feed my amp it's signal.
Correct?
I found this video on the net
Is this the procedure I should use to set this bass dial for my output feeding my amp?
Disconnect the speaker leads from the amp and play the music until I see the maximized light start to illuminate on loud sections of music then back off a bit?
tain
Or would you guys just be hooking a DMM up to a set of RCA's coming of the Bass output feed and adjust the bass dial on the LC2i until I see a certain voltage output on the DMM?
Next I will need to set the gain on the Nakamichi.
I'd like to use the DMM method I read about on the Keep Hope Alive Thread here > http://forum.sounddomain.com/ubbthreads.php?ubb=showflat&Number=1294233&page=1#Post1294233
Can someone please approve my math?
He says use Sub RMS Wattage X Final Ohm load
I'm using a single 13av.2 D2 Rated @ 1200RMS wired to 1Ohm so that's 1200X1 = 1200
And then the square root of 1200 is 34.6
So I should be looking for 34.6V ac on my fluke correct?
Does anyone have a link to a torrent for the tone CD by chance?
I guess I'll need that tone to get started.
Any advice is greatly appreciated I want to do this right and with the additional gains and bass processing with the LC2i in the mix I want to make my adjustments in the correct ways.
Correct?
tain
