Adding a digital volt meter
mrpep
chicago
I ordered a voltage meter for my van so I can observe voltage stability , drops etc etc . I know I can run wires from the battery but would like to take a short cut if there is one . Can I tap into the lighters positive and negative or must it be the battery ? Any other suggestions ??
in my truck that's how I did it. Ran one from amp pos and one from amp neg and ran wires with my other wires to the front and volt display sits right in the tray underneath where my head unit is. But not sure if anyone else has or not but I put a toggle switch on my pos wire so that way I can shut it off when the vehicles not running. There's probably a better way to do it but it works good for me.
I have three wire volt meter. One pos and one neg wire and then a remote wire for on and off. No need for toggle switch with three wire Meters... But to the OP yes you want you meter wires right at the amp so you know what voltage you amp is seeing.. That's the whole reason to have a volt meter.
Run a relay that turns on with your amp and connect it to the amp terminals for the constant positive and ground. Then run wires up to your dash for the volt meter
865
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
756
Thanks. That makes sense. It sounds pretty good as is.
956
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
mrpep
mrpep
chicago
adulbrich
    May 20, 2024
    May 20, 2024
