Active vs. Passive (specific application)?
BIG-SMOOTH
I'm going to order a Memphis Belle next week and I need to order my new front stage, but I'm a bit unsure as to which route to go. The amp is rated at 75x4@4ohms or 230x2@4ohms bridged. Should I just order the raw drivers and run active with 75 watts to each speaker or order the full set with crossovers and put 230 watts to each side? Obviously I would have more control and tuning abilities with the active setup, but I'm concerned that I won't have adequate power going to the mids to really make them shine. The comps I'm looking at are the CDT M6 with drt-26 tweeters.
On the other hand, I'm still considering the ID Chameleons which are available in 2 ohm models which would allow me to put 75x2 to the tweeters and 115x2 to the mids, eliminating my concerns if I went that route.
What do you guys think? Eliminating the passive crossover on the CDT set saves me a bit of money, I just don't see 75 watts doing that midbass justice.
It really depends on the driver you use. 75 watts will be fine for the Seas CA18RNX. The RS180 might be a little starved though.
Also, don't worry about impedance. You can take the 8 ohm version of the Dayton RS180 and do a direct comparison with the 4 ohm, and you won't hear much of a noticeable difference.
Here's a link to explain how impedance, and speaker sensitivity actually works.
http://www.diymobileaudio.com/forum/showthread.php?t=31
For an out of the box DIY driver that will sound good with little tuning, the Seas CA18RNX, or the P18RNX are hard to beat. The CA18 is a better driver when using limited processing because it rolls off on the high end naturally, and doesn't need a low pass crossover. It's also very sensitive and will get get decently loud off your 75 watts (about 40 actual because it's 8 ohms).
If you have a head unit that has a high pass crossover so you can bandpass your mids (i.e. high pass at 80hz from head unit and low pass at 2.5k from the amp), then your speaker selection increases greatly. If your head unit doesn't, then you're relegated to using the amps crossover as a high pass (the Belle doesn't band pass that I know of), so you'll need a speaker like the CA18 that rolls off naturally.
I appreciate the help, but I'm not looking a different comp set. I'm basically just wanting opinions on whether or not 75 watts is going to be enough for the M6 midbass.
the amps rating doesnt make sense to me..
75x4=300
230x2= 460
Why would it be 160 higher on 2ch if its still 4ohm. wierd..
You would probably want about 150 to each m6. and the drt-26 would be fine 75w. Like you stated. See how it is active 75x4. And if its not that good than you should get significant more power with the passive crossover.
Conventional amps work differently than the JL's that you are using in your setup. Ideally I would love to run a JL Audio 450/4 for an active front stage and a 1000/1 for the sub(s), but the best price I've been able to find from an authorized dealer was $1200 for the pair which is a bit more than I care to spend right now. That would give me...
150x2 to the mids
1000x1 to the subs
Would be perfect if I had the budget for it. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I will be running a belle just like you in my next setup, with the cdt M6 mids and Es-01 tweets, but i'm running them passive through their x-overs. So they will be bridged, I hear the M6 is a strong midbass performer so I'm opting to give them more power.
I'm thinking that is probably the best option. Slightly less tuning abilities and a bit more money in exchange for quite a bit more power.
CDT Makes EXCELLENT xovers, designed very well for their drivers. And, ya know... they would know best //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
nG
I'm sure the crossovers are of high quality, but if going active didn't have an advantage over them I'm sure the guy I'm buying them from wouldn't have recommended buying just the raw drivers since it means a smaller sale for him. Plus he runs active in his personal car using CDT comps. djdilliodon is the dealer i'm referring to.
Indeed.
Just letting you know that CDT makes particular well designed xovers.
I know Don, have done business and pointed business his way for years and years.
nG
Yeah, I've dealt with Don before also. Bought a set of HD-642 comps off him a few years ago, but I sold the vehicle before I ever got to install them. He's definitely a good guy to deal with. I had him on AIM for over an hour the other night going over all my options. Not too many dealers would spend that kind of time with someone for a $280 sale.
I'm just going to go with a passive setup. I have no intention of competing with the truck so the super fine tuning really isn't THAT necessary anyway. I guys I'll have to get ahold of Don again and see how much extra for the crossovers.
150x2 to the mids
1000x1 to the subs
thats what i started thinking. would be a 2ohm load. got it now!
BIG-SMOOTH
BIG-SMOOTH
Pottsville, PA
alphakenny1
