Active Cooling for a Sub... The possibilities
Eugenics
Princess
As i understand it alot of wattage barriers are due to thermal limitations...
would there be anyway to design a watercooling system for a speaker (it dosen't take too much to build a water cooling system) or possibly a phase change cooling system? (phase changing is basically using a compressor and assembly from a fridge to cool to insanly low temps...)
discuss
unnecessary, and even if u could start feeding it more power, chances are you'd exceed linear output since the subwoofer was made to max at a certain point.
my thoughts were that you could run it far above the normal rms rating.... it wouldn't be nessicary, but neither would a wall of 12 8's, like that amego has
In a sealed enclosure yes. But in a vented system, especially an SPL setup where its burped very near tuning, thermal limits become the dominate factor, not mechanical ones.
Love the sig //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And I'd like to add that you are correct unless something mechanical actually fails before the coil burns up (I'm sure you already knew that, just adding it in for any 'n00bz').
Thanks. lol Its caused alot of stir on the various boards I use it on. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And yes, my comments on speaker limits were based on regular occurances. Failure due to part or manufacturing defect cannot be predicted, nor compensated for.
Eugenics
Princess
Eugenics
Arbys
audioholic
