Sold ab sq 780 4 channel fs
SQ-780 Amplifier Specifications:
Power Output (DC 14.4V):
RMS @ 2 Ohm, Stereo: 160W x 4 Ch.
RMS @ 4 Ohm, Stereo: 100W x 4 Ch.
RMS @ 2 Ohm, Mono: 300W x 2 Ch.
RMS @ 4 Ohm, Mono: 260W x 2 Ch.
S/N Ratio: >100dB
THD (IHF-A): 0.03%
Channel Separation: >55dB
Input Sensitivity: 0.15V – 5V
Input Impedance: 47K Ohm
Slew Rate: 10V/Usec
Damping Factor: 200 @ 4 Ohm
Fuse Rating: 40A x 2
Dimensions (in inches):
Width: 9.54"
Height: 2.13"
Length: 17.7"”
Features
MOSFET Power Supply Amplifier
Double Sided Epoxy Through Hole PCB
Gold Plated Brass Set Screw Terminals
2/4 Channel Input Selector Switch (4 Ch. Only)
24dB/Oct. Crossover - Variable High Pass Crossover (30Hz ~ 500Hz) - Variable Low Pass Crossover (30Hz ~ 500Hz) Variable Subsonic Filter 10Hz ~ 100Hz
Variable 0dB to 18dB Bass Boost at 45Hz
High/Low Level RCA Input
Power and Protection LED Indicators
2 Ohm Stable Circuits
Soft Start/Mute Circuit
Tri-Mode Output Configurations
my camera batts are dead,but for now i pulled this 1 from the net,mine looks better.
matrxx dude
TEAM DB UNIT
matrxx dude
tifton ga
matrxx dude
